Skrivet av: intercler1
« skrivet: augusti 06, 2017, 22:05:31  »
Hej!
Säljer nu min Volvo 360!
- MOTOR -
- B200F
- 940 GRENRÖR
- 940 IC
- V70R TURBO / NY ORIGINAL
- STÄLLBAR BTR
- GLT TÄNDBOX
- ALLA TÄNDDELAR NYA
- PACKNINGSSATS + PLANAD TOPP
- 100% ETANOL
- 0,6-0,8 BAR LADDTRYCK, BÄNKAD 289HK PÅ 1,0 BAR
- VÄXELLÅDA -
- NYA LAMELL + LAGER
- NY FÖRSTÄRKT TRYCKPLATTA
- HYLSA FÖRSTÄRKT
- M47R
- AGA DIFF
OBS EJ REGGAD MED MOTOR EJ BESIKTIGAD, MOTORHUV SAKNAS, ANNARS I FULLT KÖRBART SKICK!!!
ÄGT BILEN SEN 2013 OCH HAR BYGGT DEN IFRÅN GRUNDEN, INGET BONNMEK!
EJ BYTE, BVSA!
FÖR BILDER SE BLOCKET ANNONS = https://www.blocket.se/kalmar/Volvo_360_Turbo_74718776.htm?ma=1
