Författare Ämne: Etanol conversion in english?  (läst 16415 gånger)
arnagath
  • Antal inlägg: 56
  • -87 Volvo 360 GLT
« skrivet: februari 15, 2006, 10:04:27 »
Can anyone translate in english how to make 340/360 run with etanol (E85)?
I`m very interested with this subject :D
Loud pipes save lifes...
Re:Etanol conversion in english?
« Svar #1 skrivet: mars 17, 2006, 13:48:01 »
what engine does you have?
EFI or carburator?
arnagath
  • Antal inlägg: 56
  • -87 Volvo 360 GLT
« Svar #2 skrivet: april 06, 2006, 10:04:04 »
B200E..
« Svar #3 skrivet: april 08, 2006, 15:00:50 »
1) The easy way of doing it is to buy a adjustable fuelpressureregulator.
But it is more expensive than:
2) Open and hack the LMM /AFS (air flow sensor)
« Senast ändrad: april 08, 2006, 15:02:17 av FREJ »
arnagath
  • Antal inlägg: 56
  • -87 Volvo 360 GLT
« Svar #4 skrivet: april 11, 2006, 06:58:52 »
Is it B200Es pressureratio correct for etanol or do i have to do something for it?
If i buy adjustable fuelpressureregulator, will engine work?
« Svar #5 skrivet: april 11, 2006, 21:42:16 »
No it is only correct for gasoline  ;)
If you take a regulator from a Volvo 240/740/940 you get 3 bar instead of 2.5 so then you can mix about 50% etanol in the gasoline but not drive on pure etanol..
The engine will work, if you adjust the regulator after the fuel you are driving with..
arnagath
  • Antal inlägg: 56
  • -87 Volvo 360 GLT
« Svar #6 skrivet: april 12, 2006, 05:29:02 »
Hmm..its going to be interesting times if i make etanol conversion to my b200e :D
In sweden you have that E85 which , i suppose, are included with 85% etanol and 15% petrol.
Next week here in finland we get "ecological fuel" with only 2-5% etanol and its a little bit expencive than normal 95e fuel..and we dont get ANY kinds of tax-releaves if we drive with regular fuel or "eco"fuel >:( >:(
But maybe we have sometime also E85, or something like it and then i will convert my Volvo to run with ecofuel
« Svar #7 skrivet: april 12, 2006, 18:02:49 »
FREJ, with the fuelpressureregulator from 2/740, i would get 3 bar fuelpressure?
Maybe a cheaper way to get more fuel, instead of buying an adjustable one..
« Svar #8 skrivet: april 12, 2006, 21:49:34 »
Svensk version:
Ja det får du, Nemesis gjorde så på sin, han tog från 940 men jag tror att det är 3bar i alla stora volvo.
Man kan oxå klämma ihop sin original för att få den att ge högre tryck, vet inte hur mycket man ska trycka dock..
English version:
Yes you get! Nemesis did so on his car, he got a regulator from 940 but I think that all the big volvos has 3 bars..
You could also squeeze your original one to get it to give a higher pressure, but I dont know how much to squeeze..
« Senast ändrad: april 12, 2006, 22:51:47 av FREJ »
« Svar #9 skrivet: april 12, 2006, 22:18:59 »
English version:
The fuel pressuera regulator from 940 doesn't fit since it has a different fuelrail. At least on my B230FT -98.
The fuelrail itself is bolt-on however so it's not a big problem to make it work. I'm not sure but i think the injectors fit both fuelrails so it shouldn't be a problem to make it work.
Be careful if you compress your fuelpressure regulator! It only needs a couple of milimeter or so. You should have a fuel pressure gauge installed and raise the pressure in steps. That's another handy thing about the 940 fuelrail, it comes with a valve that makes it very simply to messure the fuel pressure.
Svensk version:
Bränsletrycksregulatorn från 940 passar inte då det sitter ett annat bränslefördelningsrör på 940. Åtminstonde gör det det på min -98as B230FT.
Bränslefördelningsröret passar dock från 940.
Tror att spridarna passar i bränslefördelningsröret från 360 så det ska inte vara nåt större problem att få det att funka.
Var försiktig med att klämma ihop bränsletrycksregulatorn, det behövs inte många milimeter. Det är bra att ha en bränsletrycksmätare inkopplad och pressa ihop den i omgångar. Ytterligare en bra sak med 940 bränslefördelningsröret är att det sitter en ventil på det som gör det lätt att mäta bränsletrycket.
Jobbigt att skriva samma inlägg två gånger, på olika språk, hoppas att båda versionerna är förståeliga då jag aldrig kom längre än Engelska A i gymnasiet  :-[
AntonL
  • Antal inlägg: 66
« Svar #10 skrivet: mars 01, 2007, 12:57:35 »
Svensk version:
I Sverige har all 95-oktanig bensin i Sverige blandats med 5 % etanol sedan 2004.
English version:
Since 2004 all 95 octane gasoline in Sweden containes 5% ethanol
